I REPLACE THE DRIVE SHAFT FIRS THINKING THIS CUD BE THE PROBLEM BECAUSE HAVE A OIL LIKE FROM TRANSMISSION SEAL I REPLACE THE TRANSMISSION SEAL AND THE CENTER DIFFERENTIAL FLUID AND ALSO DRAPE THE OIL PAN OF THE TRANS,REPLACE THE OIL, TODAY I REMOVE Torsen Center Differential,I TAKE LOOK AND I FOUND GOLD POWDER
ON THE OIL I DO NOT FOUND NO HARDWARE BROKEN ONLY THE GEAR WAS SHAINE
Mar 12, 2010 at 9:17 PM
