Hello, I just purchased this car and It drives slow it will shift slowly with a little gas but if you depress pedal it revs rpms up but wont shift up until you ease up on gas until it is just a little then it will shift up through gears.
Mechanic thinks it is a clogged cat tripping codes and recommends replacing cat.
Theese codes. p16684 p16687 p16806 p18014 p1606 came up when scanned.
Does this sound like a bad cat causing theese codes except for the abs code?
What is the least expensive route to fix so car will have adequate power>
Best Regards,
Best Regards,
Mar 7, 2009 at 8:17 PM
