1996 Audi A4 starting
1996 AUDI A4
BMW520I
Engine Mechanical problem
1996 Audi A4 4 cyl Two Wheel Drive 147000 miles
hi my problem is that i start the car the engine starts and then stops strate away it can do this for some time and then it will start and drive fine the car dose work better when it is wet it has had a full servace and timing belt at 144000 and was doing the same before and it has the same problem when the engine is hot of cold i hope you can help thank you
Sep 15, 2008 at 5:52 AM
For a start have the fuel pressure check and come back with the readings before we move on to other areas-
Sep 15, 2008 at 6:00 AM
