1996 Audi A4 ignition switch/transmission interlock
1996 AUDI A4
100,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVEDARBY
  • 10 POSTS
the shift lever will not move into reverse or park and the key is stuck in the ignition switch, what is the easiest way to get it into park and remove the key?
Aug 1, 2008 at 2:58 AM
KHLOW2008
  • 41,814 POSTS
Hi davedarby,
Thank you for the donation.
The interlock system seems to be the cause. Check if the brake lights are working. (Fuse #13 (10A))
Look for slots or button on the gear shift panel, it can be used for manually getting into park.
Aug 1, 2008 at 5:18 AM
DAVEDARBY
  • 10 POSTS
ok great I will ck that fuse
the button on the side of the shift lever is frozen, wont depress at all, btw
thanks
Aug 1, 2008 at 2:31 PM
KHLOW2008
  • 41,814 POSTS
Hi davedarby,
If the button is frozen, you might have a situation here. Something might have broken and is obstructing the lever/button/interlock solenoid.
You would need to remove the console to get at it.
Aug 1, 2008 at 3:35 PM
DAVEDARBY
  • 10 POSTS
ok so the interlock works with a solenoid off fuse 13?
what does the button on the side of the shift lever do?
activate the solenoid?
thanks DD
Aug 1, 2008 at 3:41 PM
KHLOW2008
  • 41,814 POSTS
Hi davedarby,
No, the solenoid works of Fuse #231. Fuse #13 = brake switch. When you depress the brake pedal with ignition switch on, do you hear the interlock solenoid clicking?
The button is for manually bypassing the interlock solenoid.
Aug 1, 2008 at 4:10 PM
DAVEDARBY
  • 10 POSTS
ok I'll try that and get back to you I'm not with the car right now
thanks DD
Aug 1, 2008 at 4:45 PM
DAVEDARBY
  • 10 POSTS
Yes I can hear the solenoid clicking when I press on the brake pedal
brake lights are working too
Aug 2, 2008 at 11:33 AM
DAVEDARBY
  • 10 POSTS
so I guess its time to remove the console?/find out what is broken in there >
Aug 3, 2008 at 12:42 AM
KHLOW2008
  • 41,814 POSTS
Yes, that is the next thing you need to handle.
Aug 3, 2008 at 10:19 AM
DAVEDARBY
  • 10 POSTS
ok I removed the console and the solenoid operates properly, moving the pin out of the shifter, but the shifter still will not move past neutral not into reverse or park. what next?
thanks DD
Aug 3, 2008 at 12:45 PM
DAVEDARBY
  • 10 POSTS
Hi I just made another donation but im not sure it went to the right place, as it didnt show up on this page
anyway the shifter will not move am I looking at internal trans problems?? god I hope not
Aug 3, 2008 at 1:47 PM
DAVEDARBY
  • 10 POSTS
It appears I am on the wrong track, as the owner's manual says the button on the side of the shift lever HAS to be depressed to move into park
Aug 3, 2008 at 4:02 PM
KHLOW2008
  • 41,814 POSTS
So the problem is now solved? lol.
Aug 4, 2008 at 7:09 AM
