Antenna works but motor will not stop—it pushes the mast all the way out.
I believe this is a matter of the stop switch inside the antenna mechanism. This switch tells the motor to stop when the antenna is extended.
Rather than "re-invent the wheel," perhaps someone can tell lme how to set the stop switch correctly so that the antenna stops when it should.
Mileage on car—190,000
engine size—1.8 l gas
Nov 2, 2007 at 12:18 PM
