1990 Audi 5000 Cranks but no spark at the coil
1990 AUDI 5000
BIKERGAR1
1990 Audi 5000
The coil tests good with an ohm meter and it has 12v at the + and - sides (a little less when cranking), but I have no output on the high energy side. I have tried known good coils with the same result. What else is there.
Apr 29, 2008 at 8:00 AM
2CARPRO JACK
  • 11,533 POSTS
I cant find your car in my software, so this is entirely referenced from other cars. If you dont have a pulse on one side of the coil, the ignition system isnt seeing the engine turning.Does this car have a crank angle sensor or cam angle sensor? If so I would probably start there
Apr 30, 2008 at 7:41 AM
