The drivers side temperature control no longer regulates the drivers side temperature. I have a 2010 Town and Country Van with Automatic Temperature Control. It has two rotary knobs to set Drivers sides and Passenger side temperatures. On the drivers side, you can turn the temperature knob to any temperature, and the number changes, but the vent output is whatever the outside air is. However, the passenger side temp control works normally. I assume this is either an electronic malfunction where the correct signal is not being sent to a damper control or a mechanical problem. Has anyone experienced this type of problem and what did they do? Thank you for your time.
Oct 12, 2013 at 8:42 AM
