i have a problem when accelerating to change gears. it starts spitting and backfiring between 2,000 and 3,000 rpm's. also when driving at 55 mph and above on the highway. we have replaced spark plugs, wires, ignition coil, ignition switch, TPS sensor, MAF sensor, distributor cap. we have checked vacuum lines and EGR system, unplugged the 02 sensor, checked fuel pressure, replaced fuel filter and air filter. engine idles fine. replaced catalytic convertor and muffler. replaced plenum gasket. replaced the ECU. no check engine light.
Oct 25, 2020 at 1:35 PM
