After changing spark plugs and testing fuel injectors in the first start the AT Check light came on.
Now i do have a really weird problem.
The engine gives code P0507 Idle Speed Control system ISC.
I have replaced the throttle body but still the throttle will not relearn.
Not with scan tool nor with manual procedure.
Now the AT Check light comes on at low idle.
If the RPMs goes over 1,500 the light will go away.
In Drive mode the car kicks until the rpm goes over 1500 and the car goes smoothly with smooth shifting/
Does P0507 code causes AT Check light on in low idle or we destroyed the transmission valve body for good?
I wonder what have we done to the engine wires that caused AT Check light to come.
Before the service the automatic transmission was working perfectly.
The car has at least 14,000 miles on it.
Oct 13, 2023 at 12:26 AM
