Hello all, first post on the forum nice to meet you.
So I bought this vehicle months ago and realized it had an EML. I checked and the EML was for bank 1 lambda sensor, so I got it changed and still got the same fault codes. I then took it to a mechanic and he changed the timing chain, the water pump and the oil. I was having a rough idle at the time and this helped a little bit with that but it did not sort the sensor light. I then got a code showing for a misfire so I took it back to the mechanic and they said the coil pack was done and that I needed a new one. so I got that done as well. Again it improved the idle however I still kept getting this bank 1 sensor fault code and EML. What could be causing this if it is not the actual sensor?
Also, my engine is rattling like a bag of spanners once again even though I have a new coil pack and a new timing chain. It would also now appear that oil is leaking from somewhere on the engine block.
I know it complicated but any help would be very much appreciated.Thank you.
Oct 31, 2017 at 5:34 PM
