Hi, doing the timing belt and am a little confused with the belt tentioner. I have had to replace the bolt with a std hex head bolt. But when I tighten the bolt to the new belt mark and then run the belt around a couple of times until the marks line up again. the belt tension mark has moved to eh g tighter? Could some one please explain this and how to stop if need to? Please and thank you.
Astra 1.8l x18xe
Astra 1.8l x18xe
Aug 14, 2019 at 8:36 PM
