Shaking violently and raw fuel smell
2008 VAUXHALL ASTRA
87,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
PANICATTHEASTRA
I’ve got a Vauxhall Astra Mk5 (H) 2008
Breeze edition, 5dr, 1.4l, petrol, manual
The car seems okay for the first 5-10 minutes of the drive, but then:
>The car shakes quite violently, inc. steering wheel, doors, gear stick, and with the bonnet up the engine is shaking.
>The car feels like it wants to stall when:
* In 1st gear at any point, especially when bringing it up to the bite
* In 2nd gear when travelling at 20 mph+, 3rd gear when travelling 30 mph+ etc.
>I can’t really get above 1-2 mph in first gear, and the car throws itself back and forward as if it’s going to stall even when I’ve got my foot on the accelerator.
>If I start the car within 5 minutes of turning it off, the issues are instantly present, it’s almost as if they occur once it’s ‘warmed up’.
>I’ve had it in the mechanic, and he’s replaced the temperature sensor and a leaking oil filter.
He couldn’t figure out why it was doing it either.
>I’ve also tightened the jubilee clips on the air intake pipe as they were very loose, but the issues still seem present.
>The engine management light sometimes comes on but it only reports P0170, hence why I checked the air intake pipe.
>The estimated miles remaining went from 90 down to 72 on a 2.5 mile drive into work this morning.
Any help would be appreciated!
Thanks!
Jul 19, 2019 at 1:33 AM
Welcome to 2CarPros.
That is a big drop in MPG. What I recommend starting with is the fuel pressure and regulator. Have you noticed any fuel smell or gray / black smoke from the exhaust? If so, start with pressure. Here is a link that shows how it's checked:
If the pressure is good, next confirm the catalytic converter isn't plugged. Here are links that discusses the converter, symptoms, and how to check one:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/catalytic-converter-replacement
Let me know what you find.
Jul 20, 2019 at 9:53 PM
