Assembly order of coil packs for firing sequence
2000 CHEVROLET MONTE CARLO
112,219 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
TARIQ KYAM
Changed plugs and wires on my car and now it wont start. When it did it ran badly undriveable.
Oct 14, 2020 at 6:37 PM
I attached three pics. Pics 1 and 2 shows cylinder locations. Pic 3 shows where the wires attach on the coils. Pic 4 shows the cylinder locations from a top view.
Let me know if this helps.
Oct 14, 2020 at 6:57 PM
TARIQ KYAM
Your information was very helpful in confirming the wiring connections.
However, the car would take so much to turn over and ran so badly that I decided to check over everything I did. As I removed each plug individually, I noticed that 4 of the cheap plugs were badly damaged: cracked, shattered and one broke off from the metal.
So I replaced the 4 destroyed plugs with new ones and kept the 2 that weren't damaged. The car started and ran well.
The next day it started to misfire and it even cut off in traffic. So I am going to change out the remaining 2 plugs from the cheap batch and each of the coil packs just to be safe. Once again, thank you for you very helpful diagrams and info.(I have no idea why the cheap plugs got damage like that from cranking the engine. When I put them in they appeared new; maybe they weren't).
Oct 20, 2020 at 4:28 PM
Wow, what kind of plugs were they? I don't want to get that brand. LOL
Let me know if the other two fix the issue.
Oct 20, 2020 at 4:56 PM
