asd problem
1996 CHRYSLER CIRRUS
183,000 MILES
JD2012
car has spark but no injector pulse or fuel pump. relays ok sensors ok fuel pump ok new distributor why wont start
Apr 23, 2013 at 12:39 PM
CARADIODOC
  • 34,306 POSTS
Have you checked for diagnostic fault codes? How do you know the fuel pump is okay? How did you determine the injectors are not working? Can I safely assume you have the 2.5L V-6 engine? Need to know which engine you have when discussing an engine problem.
You listed "ASD problem" but you didn't say what that problem is. If the automatic shutdown relay is not turning on you can't have spark. The ignition coil or coil pack, and the injectors are all fed by the ASD relay. If you indeed do have spark but no voltage to the injectors during engine cranking there would have to be a corroded splice in the wires that feed those circuits.
Apr 23, 2013 at 2:12 PM
