The ASD relay is inside the cower module by the battery for carbureted engines. It is listed as "upper right front cowl" for fuel injected engines. I searched for quite a while, but could not find a drawing to show its location. Good thing I did not say where it was, because I just stumbled on a drawing, and it is somewhere else.
This drawing shows it to be right above the logic module which is behind the right kick panel in front of the passenger door.
The fastest way to tell if the ASD relay is working is to measure the voltage on the positive terminal on the ignition coil. This is best done with a test light as most digital voltmeters respond too slowly. You should see twelve volts there for one second when you turn on the ignition switch, then it should go to zero volts. If you see that, and/or you hear the hum of the fuel pump, the ASD relay is working and the computer has control of it.
Next, that twelve volts must come back during engine rotation, (cranking or running). If it does not, the distributor pickup assembly was the logical suspect. Those had a very high failure rate. Check if the distributor shaft is rotating during cranking. If it is not, suspect a broken timing belt.
If the twelve volts does come back during cranking, you have either a loss of spark or a loss of fuel pressure, but not both. Check for those two things to see which is missing.
Jan 25, 2018 at 4:17 PM
