brakes are sticking and locking up truck is being held back
2007 CHEVROLET SILVERADO
135,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
WILLIEDYNAMITE11
  • 37 POSTS
When I accelerate it feels as if my truck is being held back or something is keeping it from having full power. there's a grind sounding noise from the rear end, but I've changed the differential fluid . Also noticed significantly when turning a corner. Any insight or help would be greatly appreciated.
Jan 6, 2020 at 11:35 AM
I am going to assume you have rear disc brakes just because if you have rear drum then the parking brake is part of the rear shoes. However, if you have rear disc brakes then the parking brakes are inside the rotor. A lot of times these get hung up and will start dragging and making noise once they are worn out. I would suggest pulling the rotor off and looking at the parking brakes to see if that is the issue.
Jan 7, 2020 at 5:09 PM
WILLIEDYNAMITE11
  • 37 POSTS
No I have drum brakes in the rear.
Jan 9, 2020 at 12:14 PM
Okay. That makes checking this easier to check. Lift the rear of the vehicle and put the transmission in Neutral (block the wheels so it doesn't roll) and spin the rear tires. With no parking brake and in neutral, they should spin pretty easily with very little drag from the brakes. If they do then you have a different issue. If not, then we need to remove the drum and take a look.
Jan 9, 2020 at 6:27 PM
A1AADVANCEDMARINE
Truck listed above is the new body model. So my mechanics helper accidentally put about an ounce of power steering fluid in my brake reservoir. I didn't have any issues right away but maybe a month or two later I started having problems with the front brakes locking up. The pedal starts to get stiff and you can feel the resistance building up until the truck will stop itself once you let off the brakes. Pretty soon the truck will not be drivable or movable. The only way to get it moving again is to crack the bleeder screw on either side of the front calipers. I immediately had my buddy's shop replace the passenger front caliper (old one had a ton of tar and was looking pretty rough) and both front brake lines. I also had him reset the ABS and bled the system. Left his shop and 10 miles or less back to the brakes locking up. He instructed me to remove both ABS fuses and see if that stopped the issue. It has not. I am at a loss and my buddy's shop is too swamped to get me back in anytime soon. I am a marine mechanic and am confident I can sort this out with some help once I get pointed in the right direction. Any insight would be greatly appreciated. (Have Haynes Shop Manual on this truck as well) Thanks 2CarPros in advance!
Feb 22, 2021 at 11:37 AM (Merged)
That isn't good. Power steering fluid will cause a lot of damage, quickly. Power steering fluid will cause seals to immediately begin swelling. As the seals swell, they expand and block passages causing issues such as you described.. In this case, I feel the return ports in the brake master-cylinder are blocked and preventing the brakes to not release. Also, braking produces heat and the fluid to expand. If the fluid can't return to the reservoir when you release the pedal, due to swollen seals, the brakes remain applied, creating more heat and expansion, and eventually the brakes lock up. Usually, that will happen within a short distance.
The only truly effective way to fix the problem is to take everything apart and replace every rubber part and flushing out the others. Now, since some parts were already replaced, chances are they are now contaminated as well.
I wish I had a better answer, but I feel this is what has happened.
A1AADVANCEDMARINE
So the fluid has been filled and bleed a few times before the front brake lines were replaced. I feel confident saying that the power steering fluid would have been flushed out prior to the changing of the brakes lines. I understand that this is a split system and also hydro boost assisted. One other piece of info I forgot to add is that the brakes lock up much faster if the truck sits and idles as opposed to driving. Wouldn't the rear brakes also have been locking up from the power steering fluid put into the master cylinder? I know this is a whole can of worms and if I have to rebuild the entire braking system I guess that's just the route I will have to go. I am doing my due diligence and research and will get this solved one way or another...Just hoping I can purchase rebuild kits for some of these parts and not get sucked into having to buying a ton of high priced parts.
I have what will sound like a stupid question. Do the brakes lock up when making sharp turns only? There was an issue with the hydro boost systems years ago. The brake pedal would actually move and lock the brakes when making sharp turns.
Honestly, the person that put the power steering fluid in it should have insurance to cover this repair. It wasn't your fault. I'm not sure where you are located, but here in PA, we can't have a business without insurance. I realize he is a friend, but he left you with a mess. I would hope he would make it right for you.
JATEBEE
You can drive about 20 feet when the truck stops without touching brakes. When I say stop I mean almost puts you through the windshield. After it sits a while it will drive about 10-20 feet before it does I again. You can hear a clunk from the back end. Back tires will spin but front end won't move if you gun it without touching brakes.
Has any work been done to the front brakes recently? What I need you to try is this. Safely lift the front of the vehicle so you can turn the tires by hand. I realize you may not be able to at first.
Once it is off, have a helper press the brake pedal so the front wheels lock up. Then, open the bleeder valve on the brake caliper to see if the wheel turns. If it does, close the bleeder and replace the rubber brake hose. If it doesn't release with the bleeder open, either the caliper piston is frozen or the caliper slides are frozen.
Do this and let me know the results. Once you tell me, I will provide you with what needs done next.
I attached a picture below if where to find and what the bleeder looks like. Be careful when loosening it because if it breaks, you will need to replace the entire caliper.
Let me know what you find.
BEBA123
I have a 2006 Chevy Silverado LS , T engine and my front brakes locked up on both sides. I changed the calipers, brakes and high pressure lines that run from the caliper up.The brakes are still locked up. Do you have any suggestions as to what it might be? The ABS light on the dash is not lit, nor is the brake light. I know that they do work because I unplugged one of the ABS lines and the dashboard lit up. I have also tried bleeding the brake lines. If I remove the caliper and push the piston back in,after reassembling,hitting the brake pedal again, the pistons will not retract.
Both fronts are locked up. Also, I have already checked the rubber hoses.
Hey BEBA123,
The front brake lock up because the caliper cannot slide freely, you must remove the calipers and service the caliper slides or the brake booster is not returning fully. When the brakes are locks release the bleeder on the caliper if the wheel turns its a pressure issue if not it will be a caliper problem.
This guide can help you see how to service the slides
If that seems to be okay then while the brake are locked up loosen the master cylinder mounting bolts and allow the master to slide forward about a 1/4 of an inch. If the brakes release it means the push rod for the master coming out of the booster is to long and needs to be wound inward. This allows the master to fully unload keeping the brakes from locking up.
Please let us know what you find so it will help others.
Best, Ken
CEDARSTUMP
Brakes problem V8 Two Wheel Drive Automatic 85000 miles
I have a 2005 Chevy Silverado that I recently purchased. The problem that I have is when I first back out of the driveway in the mornings. When I go to put the truck in drive it will not go because the brakes are locked up. If I put the truck in reverse again and then back in drive it will go. As I go out the gravel drive and press the brakes both back tires will lock up and slide. This only happens in the morning when I leave for work. I can not see any brake fluid leaking from the inside of the wheels like a brake cylinder leaking. Does any one have any suggestions. Thanks in advance for your help
Feb 22, 2021 at 11:38 AM (Merged)
When rear brake lock up it means the shoes are getting to small to work right with the drum and its time for a rear brake job.
Here is a video that will help you get the job done.
https://www.youtube.com/watch?v=-Ts8SRUxRc8 its an older car but the idea is the same.
MMORLAND
Front brakes will lock up after car drives a while, calipers will not release. They sometimes do, sometimes do not. Causes the car to overheat because the rpm's rev up as the brakes are engaging. Replaced pads, rotors, calipers, master cylinder , brake booster and installed AcDelco hoses. Same issue occurs. I have had to replace pads, rotors and calipers four times in a year and a half. Removed ABS fuse, same issue. I am baffled.
This sounds like the brake booster rod is extended out to far not allowing the master cylinder to return fully. To be sure when the brake are locked up loosen the brake master mounting bolts. If the brakes release you have found the problem.
MMORLAND
Ken, Thank you for the information. How do I adjust the booster rod to not extend out too far? Thank you
Remove the master (pull it away from the booster) you will see the rod has threads on it, turn the plugger inward until you have 1/8 inch freeplay.
BLAKE DOSSEY
The truck drives just fine if I am only going straight. I guess the brake pedal could be a little firmer, but otherwise it brakes fine. My problem is when I turn. When I am reversing out of my parking space and the wheel is turned, the front brakes lock up. When I turn a corner or drive through an intersection and turn the wheel the front brakes will lock up. It does it when I turn both ways. From all of the blogs I have read I am leaning towards replacing the power brake booster, but I could really use some advice from someone who has experienced or heard of this problem.
Thank you,
JIS001
  • 3,412 POSTS
The only way I see the booster doing that is if the master cylinder were leaking and the booster was sucking in the fluid. Do these and let me know what you find. Pull the master cylinder forward and inspect the inside of the booster for fluid. If there is brake fluid inside then replace both the master cylinder and the booster. Also wind in the booster push rod 3 turns to see if that helps.
I would look at the caliper hoses to make sure they are not looped this will cause the problem. The caliper needs to be turned so the hoses are not looped.
JERRYTINNEY123
Brake line on rear right where hard line goes to rubber on rear . Replaced 7"of it . No leaks now but not getting any fluid to it to bleed . Took line off at spliter block no fluid.
Feb 22, 2021 at 11:52 AM (Merged)
Good Morning,
Make sure there is fluid on both sides of the master cylinder. if there is, then you may have a restriction in the system. Also, if you have ABS, you will need a shop to bleed the system for you as there is a procedure for bleeding the ABS system that requires a scan tool to open the ports to bleed the system.
JERRYTINNEY123
Thanks. But I do not have a scan tool.
You should be able to open the bleeder and have fluid flow from it without touching the brake pedal
BRIAN ROCHE
I had to change my brakes on rear of truck they are disk with a single cylinder piston calipers. They were working fine all I did was change brake pads now they are sticking and getting hot. I put new clips, cleaned pins.They slide easy just when I apply brakes it does not release. So they are staying stuck. What is wrong?
Good afternoon,
Do both sides stick or just one side?
It could be the calipers sticking or a brake hose that is collapsed.
https://www.2carpros.com/articles/brake-caliper-replacement
Try this, when they stick, try opening the bleeder and see if the caliper releases and the wheel turns.
One last thing. When you replaced the pads and you had the calipers off, did you by any chance rotate the caliper and link the brake hose? Double check for that.
BRIAN ROCHE
Thanks Roy. I went ahead and changed my hoses seems to be working better. thanks for reply, if something changes will get back with you.
You are welcome.
Keep us updated.
Always glad to help.
AGEE702
twice in 6 weeks,i had to panic stop,both times the rear wheels locked up.i do not have a check brake or engine light, a local ase repair shop today looked at,managed to get the front brakes to lock up,but could not determine a cause or course of action.they found no codes or trouble lights.the brakes seem to me to be not as strong as 2011 when purchased.i have had to replace ALL of the steel brake lines due to rust,late last year.all brake linings and rotors are like new.when you try to push the brake pedal to the floor,it will not.you do not seem to gain anything if you pump the brakes. at this point my best guess would be to replace the master cylinder and power booster.any ideas or possible solutions? any feedback will be greatly appreciated.thanks Bill.
HMAC300
  • 48,601 POSTS
check rear brakes for grease/oil on discs if it has it fix the leaks probably the axle seals. then try a brake bleed with a scanner as he can open all the valves on the abs unit. also look at speed sensors to see if they have rust on them at the ends as they are magnetic if they do clean it off. they may not be sending a signal to abs unit. make sure that sensor wheel is ok as well when you spin the wheel. in pic one arrow points to sensor ring on wheel and other to speed sensor bolt. be careful with sensor as wires are very thin and can break easily ......
JET71
Hi, while driving down the road the brakes apply (you can feel the dragging, it progressively gets worse until the truck almost won't move) total distance of drive maybe 5-6 miles. you don't even have to touch the brake peddle. I got it back to the garage (the rear caliper piston seals caught fire it got so hot!loosened the bleed screw on right rear, both rear brakes released. then i went to the front and loosened the left front bleed screw and both fronts brakes released! I pulled the fuse on the ABS 2 years ago due to ABS operating as you almost come to a complete stop! (it is a hydroboost system)
Feb 22, 2021 at 11:53 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi jet71,
Thank you for the donation.
From the symptom description, the pressure is not being released and it could be form the master cylinder or ABS accumulator.
To identify the source, when problem occurs, loosen the master cylinder brake pipes and if the brakes releases, the fault lies with the master cylinder. If the brakes does not release, then the fault would be with the ABS accumulator.
ABS Accumulators tends to fail over time if it has been diasbled without being removed from system.
