are green injectors or orange color in cylinder one and two or on three and four
2002 KIA SPORTAGE
98,000 MILES • 2.0L • 4 CYL • 4WD • MANUAL
ALESANDRO
I bought this car, the former owner worked on it and mixed up many things . it has two green and two orange injectors. I need to know which color go in each cylinder for example; should I put (green injectors on cylinder one and two) and ( orange on cylinder three and four) or reverse? please some one give me a good answer to my question. thank you very much.
May 29, 2017 at 12:17 PM
STEVE W.
  • 15,113 POSTS
Greens go in cylinders one and two, oranges go in cylinders three and four. You are welcome.
May 29, 2017 at 6:53 PM
ALESANDRO
Okay, thank you . rockauto said that too. now I got cylinder four misfire . I guess before was the number one misfire . I guess I have to replace the coil pack . I have new spark plugs. Reconditioned injectors . former owner put the fuel filter backward . I did too . but found out was wrong and corrected it. but may be damaged so will replace it too. thanks Steve.
May 29, 2017 at 7:06 PM
Steve W is one of our best!
Please use 2CarPros anytime, we are here to help and tell a friend.
Jun 1, 2017 at 11:31 AM
