Hello mechanics, soon we will be switching to the thicker 10W-40 viscosity or weight Mobil 1 High Mileage Synthetic oil from the thinner 5W-30 oil we currently have so we can cushion the excess clearance between the high mileage parts (bearings. crankshaft journals, timing chain and variable valve timing sprockets, oil pump chain, oil pump, camshaft bearings and journals, camshaft lobes, valve tappets, valve springs, valve guides), but only the Nissan car dealer would accept the thicker 10W-40 weight cushioning oil in their acceptance of customer-supplied oil and Walmart only accepts 5W-30 oil, we have this Nissan Versa since it was 3 years old and 7000 miles on it and since the beginning we have been doing 3 month or 3000 mile oil changes at Walmart, our current engine is still running but if I open the hood and stick my ear to the oil filler cap, two ignition coils that are not covered by the intake manifold, intake manifold, variable valve timing solenoids and variable valve timing sprockets, then the engine idles with a kind of growling grumbling noise and also shakes at idle or idles rough and that's why I want to cushion the worn parts with 10W-40 synthetic oil so they can smooth out and quiet down, but the Nissan dealer wants 5000 miles or 6 months between oil changes instead of 3000 miles or 3 months that Walmart used to do, my question is that is it okay to do the oil changes at 6 months or 5000 miles? anyway I know that Toyota dealers are even worse than Nissan and they want 10000 miles or 12 month oil changes and so that's why I don't see any Toyotas on the road because their engines seize up, I will also be changing the PCV valve for the first time along with the oil change because I have heard that a clogged PCV valve dilutes the oil and so it won't last 6 months or 5000 miles that the Nissan dealer wants, thank you in advance for informing me or enlightening me about the validity of the longer 6 month or 5000 miles oil change intervals, Alex Stathas
Aug 7, 2023 at 1:12 AM
