Replaced the starter solenoid then connected the negative terminal last. Ignition was then turned on and got one click and shut the ignition off. Checked under the hood and the negative terminal was smoking, removed neg cable off and it arc welded, touched negative again and still arcs and sparks ...
Dec 5, 2024 at 9:45 AM
