Aod transmission installation
1984 FORD BRONCO
382,722 MILES • 5.0L • V8 • 2WD • AUTOMATIC
GAGEBUCHANAN
During installation of my aod into my vehicle listed above with a 302, I noticed as I spin the motor over the weight of the explicate is catching the separator plate and will cause damage if I were to attempt running it. I've pulled the transmission back out and is still catching . All of the right parts are being used a 50 ounce offset flex-plate and the aod separator plate
Sep 13, 2019 at 10:08 AM
It sounds like the torque converter is not in all the way. here are two videos to help you fix the problem:
https://youtu.be/3vJAojsrfuU
and
https://youtu.be/ZC7xHVMKLRw
Please run down these guides and report back. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Sep 16, 2019 at 11:12 AM
