AOD shifting issues
1987 FORD MUSTANG
161,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
CHAVISPIERRE
  • 7 POSTS
My AOD has a full manual valve body in it and I'm having shifting issues. When I start in 1st gear and shift to 2nd gear it goes into gear but its another jerk/hesitation after that then when I put the shifter into 3rd gear it doesn't shift. I can hit neutral then go back to 3rd and still stays in 2nd. I've replaced the shifter and the shifter cable, adjusted countless times and still the same issue. I'm thinking the valve body is messed up.
Feb 20, 2016 at 1:04 PM
Yep, you are in the right ball park, please let us know what happens
Feb 24, 2016 at 12:12 PM
