Anti-theft
2011 CHEVROLET HHR
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENERAL
  • 4 POSTS
I recently purchased and had a key fob programmed to my car. My spouse has a key to the car but she does not yet have a fob. She attempted to start the car, and the anti-theft light came on. She turned the car off and attempted to start it again, and all of the vehicle's lights flashed, went dark, and her key was stuck in the ignition in the "on" position. I got home about forty five minutes later and managed to get the key out using a manual release in the steering column. However, now the car just remains completely dark, no dash or any other lights come on, and it tries to keep my key, I have to use the manual release as well. Not sure if this is an anti-theft feature, a drained battery issue or both? We did not have any of these problems until we got the key fob.
May 27, 2018 at 10:08 PM
STEVE W.
  • 15,113 POSTS
Well the way it acts sounds like a bad battery or battery connection. The everything going out hints at that. I would say to pull the battery, have it tested for charge level, CCA and reserve. If it tests good, check the cables for good clean connections at both ends. If they are good then check the master fuses in the under hood fuse box.
May 28, 2018 at 7:10 PM
JENERAL
  • 4 POSTS
Thank you, the battery had drained, due to the car locking the key in while it was in the "on" position. We think the anti-theft was engaged because my spouse's key was not present when the dealership programmed the new key fob. Unfortunately, no one told us it was a potential problem!
May 28, 2018 at 7:23 PM
STEVE W.
  • 15,113 POSTS
That would drain it. I would still test the battery, once they are drained that far they can become an issue, especially if you are in an area that gets cold.
Thank you for using 2CarPros.com. Please return anytime with your automotive questions.
May 28, 2018 at 8:53 PM
