Antifreeze leak
2000 CHRYSLER CIRRUS
181,355 MILES • 2.5L • V6 • FWD • AUTOMATIC
JR47
  • 114 POSTS
I have a coolant leak from the passenger side of the engine coming from around the water pump. At first I thought it was the water inlet pipe so I replaced that and the o-rings on it, but it's still the same so is the water pump gasket bad? I only replaced the inlet pipe cause the coolant would pool up along the bottom of the pipe. Any ideas on what else could be going on here.
Apr 12, 2016 at 10:16 AM
HMAC300
  • 48,601 POSTS
it may be a bad awater pump, have the coolant system pressure checked for leaks so you can see where it's leaking
Apr 12, 2016 at 3:31 PM
