Briefly, there is anti-freeze in my oil. I had a mechanic replace lower intake gasket. Then discovered oil pressure dropped. Oil was like milkshake. Immediately changed oil, and no major clinking noises. However, needed to change oil again about two hundred miles later. Then again, two hundred miles later. Could hear a squealing noise on a cold start and suspected it to be coming from the oil pump. Was told that oil and antifreeze will mix, and some antifreeze will separate to the bottom. Started a drip at the oil plug. Normally, the oil plug would be completely unscrewed and would not leak until pulled from the oil pan. Now with a few turns a mixture of mostly coolant and a little oil drips out. I have drained at least four quarts of this out. The squealing noise is not as long and is quieter. I am afraid there is more anti-freeze in there. Does this sound familiar?
Jun 16, 2017 at 8:10 AM
