Antifreeze leaking
2002 CADILLAC ALLANTE
160,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
WILLIAM DOW
Discovered antifreeze was leaking above my starter is this common problem? it has never overheated but tired of replacing antifreeze.
May 2, 2017 at 6:47 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Without seeing the car in person the leak can be coming from different places around the starter. What we suggest to people is perform a cooling system pressure test. You can perform this with the engine cold and turned off. It is basically a pump that pressurizes the cooling system and you can then look around the engine to see where the leak is coming from. Here is a tutorial showing how to perform this test:
https://www.2carpros.com/articles/radiator-pressure-test
Hope this helps and thanks for using 2CarPros.
Jan 27, 2021 at 5:56 PM
