Can I get an Anti-theft wiring diagram?
2001 DODGE STRATUS
100,000 MILES • 3.0L • V6 • 2WD • MANUAL
LEYNA07
  • 41 POSTS
I bought a car that I had to replace ignition switch but installed a push start. I need a diagram or schematic for system circuits due to original owners cut a lot of wires that I'm not sure what they connect to.
Jul 23, 2022 at 12:57 PM
If you look below, I attached the wiring schematics you requested. The first two are the anti-theft alarm circuit.
Pics 3 and 4 are the anti-theft immobilizer circuit. As far as the pics I attached, the schematics were one page long. I had to cut them in half to make them readable for you. I did overlap them so you can follow from one to the next.
Let me know if this helps.
joe
See pics below.
Jul 23, 2022 at 10:43 PM
LEYNA07
  • 41 POSTS
Omg, I so greatly appreciate it. i have been breaking my head trying to figure out which diagram to follow.
Aug 6, 2022 at 9:05 AM
You are very welcome. Let me know how things turn out for you or if you have questions.
Aug 6, 2022 at 7:02 PM
LEYNA07
  • 41 POSTS
Now my next problem is finding out what the fuses and relays on engine compartment fuse box and inside under dash the cover only specifies to size of fuze but not what it's for I'm going crazy trying to figure it out it's. 2001 Dodge stratus rt coupe but has a 6g72 engine standard transmission help please
Aug 9, 2022 at 8:56 PM
I'm not sure if it will help, but I attached everything I have for the fuses and junction boxes. If things were modified, I'm not sure what was changed.
Take a look through the pics below. Let me know if they help.
See pics below.
Aug 10, 2022 at 11:05 AM
LEYNA07
  • 41 POSTS
I so greatly appreciate it.. thank you so much... Hopefully it's the same....let you know if they are..
Aug 10, 2022 at 11:07 AM
No problem whatsoever. I just hope they help. In most cases, and for what reason I don't know, my manuals provide basically useless information when it comes to fuses on a Chrysler product. This what much better than I expected.
Take care of yourself and let me know.
Aug 10, 2022 at 11:22 AM
LEYNA07
  • 41 POSTS
Yes, it matched thank you so much, honestly, it helped out a lot. one last question is, now concerning the ignition switch pertaining to the colored wires what they connect to theirs several wires that I'm lost as to what they connect to. I have a picture of connector or harness not sure name of it. Not sure if that's included in any of the images you've already sent me..
Aug 10, 2022 at 2:55 PM
The black wire with the red tracer goes from the switch to the starter relay to energize it. The white wire with the red tracer comes from fusible link 8 in the under-hood fuse box. The power from that wire goes through the ignition switch and then to the starter relay when the key is in the start position, and it powers other fuses in the junction box on the left side of the dash.
I attached a pic below related to the switch and power distribution in the junction box. The black wire with the red tracer in the pic shows it is to engine controls/ignition. That is the one that goes to the starter relay primary side.
See pic below.
Aug 10, 2022 at 3:59 PM
LEYNA07
  • 41 POSTS
Now from there what wire powers the fuel pump it's new just bought knew one has power as I've tested it but won't come on when it's supposed to. I tried the starting fluid spray thing and did get car to turn on, but fuel pump won't engage can you tell me about those wires how and where they connect to please?
Aug 10, 2022 at 5:12 PM
LEYNA07
  • 41 POSTS
It's because the original owner guessing lost their keys and attempted to do I know what or why they cut wires they had no reason to cut.
Aug 10, 2022 at 5:14 PM
LEYNA07
  • 41 POSTS
Also, when I connected OBD scanner I get fault code p1610.
Aug 10, 2022 at 5:15 PM
LEYNA07
  • 41 POSTS
Only code I keep getting did the clear code, but same one keeps showing.
Aug 10, 2022 at 5:16 PM
LEYNA07
  • 41 POSTS
Assuming has to be one of the wires not connected at ECU maybe.
Aug 10, 2022 at 5:17 PM
LEYNA07
  • 41 POSTS
Everything else seems to turn on lights, headlights, gauges etc., just no fuel pump and that code.
Aug 10, 2022 at 5:18 PM
That code is for the immobilizer, but the code isn't listed for this vehicle. LOL Now I'm confused.
I have a feeling it may be the result of the PCM not recognizing a key.
Aug 10, 2022 at 10:20 PM
LEYNA07
  • 41 POSTS
But no key is being used as for having taken out if ignition and installed a push start with 3 accessory toggles. As I said, when attempting to start the car does crank over but again the fuel pump does not engage. as far as the code I'll try again to see if it pops up again.
Aug 10, 2022 at 11:29 PM
The fuel pump is shut down by an immobilizer. The other modules on the vehicle likely are waiting for clearance to allow the vehicle to run.
That is the only other thing I can think of.
Let me know. Also, I wish I could be of more help. Not being there makes things difficult. I hope you understand.
Aug 11, 2022 at 1:26 PM
LEYNA07
  • 41 POSTS
So, what if I get no ground on my relay which if I'm correct is what would engage my fuel pump to turn off which would be getting its ground from my ECU.
Aug 18, 2022 at 9:21 PM
If the fuel pump relay's primary side is not getting a ground path, the relay won't actuate and send power to the pump. If that is the case, check at the ECU to see if there is a ground presence there. You may have a broken wire or a bad connection.
Aug 18, 2022 at 10:08 PM
LEYNA07
  • 41 POSTS
Thank you, that's what I figured. Now I will be checking ECU in engine fuse box or fuse box inside car apparently there's one there too.
Aug 18, 2022 at 10:25 PM
There is one there. I attached a pic below showing its location. I hope this helps.
See pic below.
Aug 19, 2022 at 9:18 PM
LEYNA07
  • 41 POSTS
If I'm not getting ground, I check ECU, but on engine compartment fuse box or inside fuse box to test ground wire.
Aug 20, 2022 at 9:08 AM
I would first check it at the relay location in the box. If there is no ground, then I would go to the ECU and check it there. If there is no ground being provided by the ECU, chances are it has failed.
Aug 20, 2022 at 9:29 PM
LEYNA07
  • 41 POSTS
So, finally I was able to finish looking into the car and located the computer and discovered I'm not getting any power to computer. What's next for me to do? Could someone please help me out...
Sep 8, 2022 at 8:47 AM
Are you referring to the powertrain control module? Is that what isn't getting power?
Let me know so I grab the correct schematics.
Sep 8, 2022 at 6:33 PM
LEYNA07
  • 41 POSTS
Well, you see my issue is my fuel pump wasn't engaging found out not getting ground side on relay circuit but not sure what to do next. Also seems like my fuel pressure is low or is that from fuel pump not engaging. I used starting fluid to see if car would start and it did but stuck on what to do next on relay or what to check and where. I have the car listed above rt 3.0l v6 6g72 Mitsubishi engine.
Sep 8, 2022 at 8:00 PM
If you aren't getting a ground from the ECM, that is why you have no fuel pressure. I'm looking at the wiring schematic (see pic below). The ground signal is provided via a black wire. Go to the ECM on the passenger side and locate that black wire. With the battery disconnected, remove the connector and check for continuity in the wire itself. Also, make sure there is no damage at the connector or corrosion.
If that checks good, then check right at the ECM for a ground path. If there isn't one, the ECM is my first suspect.
Sep 9, 2022 at 8:14 PM
LEYNA07
  • 41 POSTS
Okay, what does it mean if or when I was checking relays with my test light last night and I went inside car to start nothing seems to power anymore was working fine right before I started checking relays what did I do that would have caused me to have no power.
Sep 17, 2022 at 8:56 AM
Have the relays been reinstalled? Have you checked to see if you may have caused a fuse to fail? Also, does anything work? For example, do the headlamps turn on, or does the horn blow?
Sep 17, 2022 at 10:18 PM
LEYNA07
  • 41 POSTS
Figure it out, but now when the vehicle starts, I have low fuel pressure. What or where do I begin to check but without using a pressure gauge if by chance is possible?
Sep 19, 2022 at 1:05 AM
To determine fuel pressure, you need a fuel gauge. What is happening that leads you to believe it's low?
Take a look through this link that explains in general how pressure is tested:
Sep 19, 2022 at 7:17 PM
LEYNA07
  • 41 POSTS
Reason being that when I disconnect fuel line very little fuel dripping or coming out not sure how to word it correctly my apologies.
Sep 19, 2022 at 7:37 PM
LOL That is perfect and no need to apologize. It sounds like you have no pressure if it is only dripping, can you hear the fuel pump turning on when the key is first turned on?
Sep 19, 2022 at 7:39 PM
LEYNA07
  • 41 POSTS
Well, I'm not getting side that makes fuel pump priming.
Sep 20, 2022 at 9:56 AM
At this point, I'm not sure what to say. With the changes that have been made, I would need to be there. I wish I had a better response.
Sep 21, 2022 at 5:18 PM
LEYNA07
  • 41 POSTS
Question in regard to my ignition switch. Now my blue with red tracer and also my blue with black tracer say one says it connects to accessory heater blower 1 and blue and black connect to accessory heater blower 2 now if I'm eliminating ignition column switch and installed push start with accessory toggles how would I wire those two wires...
Sep 24, 2022 at 10:24 AM
I'm not sure how you have it toggled, but the blue/black needs power in acc and the run position and the blue/red only should have voltage in the run position.
Is that what you need? See pic below.
Sep 25, 2022 at 5:48 PM
