Anti-theft light issue?
2008 FORD EDGE
209,000 MILES
ADAMALANSCOTT
Hello, I drove my edge home one day a few months ago. I went to leave a few hours later for work and the anti-theft was blinking rapidly and had a no crank no start. So far, I have replaced the ignition switch, PATS transceiver and I bought a preprogrammed PCM. It still has all the same symptoms whether I replace everything or not. I'm guessing it never had problems with any of these components. I have lost my job and almost my house because of this. I live in country so I really need this car to run. I just don't get it. I have checked all fuses and power and ground pins on PCM. It will not connect to FORscan to try to relearn the keys it won't do anything but blink anti theft. Please help.
Sep 16, 2023 at 7:29 PM
We need to know the code; I would do a CAN scan which will tell us what's going on. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
It sounds like the SJB is out which is common, here is how to replace it in case a code comes up for it. Check out the images (below). Please let us know what happens.
Sep 18, 2023 at 11:56 AM
