Anti-theft and gas pump
1999 MERCURY MOUNTAINEER
194,706 MILES • AUTOMATIC
NOFILTERSTARLA
The anti-theft is on and the car will turn over, but will not stay started because the gas pump is not working. is that due to the anti-theft? What can I do to fix this?
Oct 29, 2019 at 6:51 AM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros. Yes the anti-theft shuts the fuel pump off. What does the light do when you turn the key to run? Flash or stay on solid? If it flashes the system isn't recognizing the key, if it is staying on solid there is a problem in the PATS system itself.
If you have a second key that worked in the truck before you can try it. Much beyond this you need a factory level scan tool that can talk to the various modules to see which ones are not working correctly. There isn't much else that can be done without the scan tool.
Oct 29, 2019 at 6:52 PM
