Anti-theft causing vehicle to shut off after three seconds
2000 JEEP GRAND CHEROKEE
200,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
AARON212
I have the vehicle listed above that me and a professional locksmith have been trying to start for 3 days. We have finally got it to start but it shuts off after 3 seconds. We have replaced the immobilizer under the column twice, the PCM twice, reset everything, he has done you name it with all kinds of computers and devices, made countless keys and reprogrammed everything that can be reprogrammed. What is shutting down my vehicle? Please help because this is driving me insane and has cost me and my wife to miss two days of work.
Oct 6, 2019 at 6:58 AM
AL514
  • 5,462 POSTS
Hello thanks for using 2CarPros. First thing is to put the original ECM and immobilizer unit back in the car. These are programmed to work together. Changing them and switching them around will only cause more problems. You will need someone with a scan tool to reset them back to factory specs if that's the case. Put the original modules back in and try disconnecting the battery cables and touch them together. This will reset the entire system. Here's a rundown about the security system: https://www.2carpros.com/articles/how-to-reset-a-security-system
Oct 6, 2019 at 8:21 AM
