No the starter wouldn't cause the light to be on. You said it worked ok until the mice chewed on it? Go over the wires you repaired and maybe take a picture of that area. Also look for missing wires, I have seen mice damage where they actually ate the wires right up to a connector so it looked like there wasn't supposed to be a wire there. List the wire colors and we can see if there is something missing. Also might be a good idea to take a test light and check all of the fuses. There seem to be a lot of failures in the fuse boxes themselves where the fuse itself is good, but it actually isn't connected in the box due to corrosion.
In this case a simple test would be to connect a test light between a ground and the yellow wire on the starter. Turn the key, the light should come on. Even if the anti-theft is on that should still work. If not then there is still an issue in the system. Might be a failed SKIM in the column. However I would start at the damaged wiring and look up the colors and what they feed.
Sep 6, 2025 at 12:35 PM
