Anti theft light is blinking and car will not start
2018 TOYOTA YARIS
30,000 MILES • MANUAL
BLUEYEBEAUTIE
I have tried unplugging the battery and plugging it back, unlocking/locking it with the key.
Mar 28, 2020 at 12:49 PM
STEVE W.
  • 15,113 POSTS
If it is blinking the system is not reading the key as a valid one. Do you have a second key to try? The next step if the second key doesn't work then you will need to use a scan tool that can talk to the security system and determine if the problem is in the anti-theft module itself or if it isn't receiving the signal from the transponder key. Hopefully it is a bad key as the module is located behind the HVAC unit and requires most of the dash be removed to access it. The scan tool can show you what has failed.
Mar 28, 2020 at 2:50 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Here is a tutorial showing how to reset your cars anti-theft system:
https://www.2carpros.com/articles/how-to-reset-a-security-system
After reading, scroll to the bottom of the page to find Toyota. Hope this helps and let us know what happens.Thanks for using 2CarPros.
Mar 28, 2020 at 2:52 PM
