Hello, I'm Danny.
Here is the information you requested. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your truck:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
The wheel speed sensor is incorporated into the front wheel bearing-hub assembly and will have to be removed and replaced as a unit. Here is a wheel bearing-hub assembly replacement tutorial for you as well:
https://www.2carpros.com/articles/bearing-hub-replacement
I've attached picture steps below on how to change the wheel speed sensor and hub assembly on your truck. Hope this helps and thanks for using 2CarPros.
Apr 7, 2021 at 10:17 PM
