I have a fairly large amp sub setup in my truck. I have been installing stereo systems for 30+ years and have never run into this problem. I hav3 2-12" subs, each with its own amplifier. I'm running 1-0 gauge from the battery to a 4 fused junction block with 8ga to each amp from it. Also have 1-0 ground wire also to a junction block with 8ga to each amp approximately 15" long. I am using a 12ga remote turn on wire from the head unit. There is all of a sudden no output from either amp or sub. All voltage checks out at 13.8 each amp, no protection circuitry has been triggered, and i have tried at least 5 different sets of RCA's, and even went so far as to change head units trying to narrow this down. I am at a complete loss as to what is causing this. The subs also check out with my meter as good. The whole system worked fine, then inexplicably, didn't. Any help would be great. Also, what should i be getting for a reading on the amps TCA outputs when powered up? I don't have a clamp meter, just a multimeter. And what should i set it on to get a reading if a multimeter alone will even work?
Thanks in advance.
Thanks in advance.
Nov 20, 2020 at 2:52 PM
