1972 AMC Javelin engine stall
1972 AMC JAVELIN
132,000 MILES • V8 • 2WD • AUTOMATIC
JAVELINMAN
car starts fine- runs well at high rpm's. When it comes back down to idle it will sometimes idle well- but most times it stalls. If you step on gas to stop from stalling- it makes a noise up thru the carb-like sucking air. I have only driven this car in town since I've had it,{2 yrs.}but this was the first time I had it on the open road and cracked the throttle a bit! Would it be timing? not plugs or coil or carb because they're not intermittent{are they?}not fuel system otherwise would not run @ high speeds, Somebody help a brother out here! Thanks, Warren
Jun 28, 2010 at 12:23 PM
Hi Javelinman, Welcome to 2carpros and TY for the donation
Lets start by checking and adjusting the choke plate opening and the fast idle cam adjustment also test the PCV valve and then get back with some results asap.
Jun 28, 2010 at 2:23 PM
JAVELINMAN
have manual choke- it sits in open position when warm- fast idle has been disengaged. PCV valve looks okay- I can blow thru it- is that good? Its a 10$ item but not in stock-
Jun 28, 2010 at 5:10 PM
It wiil pass air one way and resist on the other end, also if you shake it should rattle-if not replace it.
Also check if the exhaust manifold heat control valve is opening
Jun 28, 2010 at 6:53 PM
JAVELINMAN
Hey, checked pcv valve- its okay- but I don't know where to find exhaust valve - also temp. gauge is reading off the charts now!I looked in TSM for location of valve, but it said on intake, near back - pass. or drivers side?
Jun 29, 2010 at 10:43 AM
The heat riser valve is located between the exhaust manifold and the exhaust pipe-also test the engne temperature sending unt
Check if it has an EGR valve-they started coming out in 1973 if so try cleaning out and see what happens-all these are okay -sounds like a carb problem
Jun 29, 2010 at 1:50 PM
