Sometimes 60 degrees or more. I have changed the sensor as well as the connector with no change. What else could be causing this?
Mar 21, 2019 at 2:27 PM
CERTIFIED EXPERT
Good afternoon,
Where was the location of the sensor you replaced? there are two sensors. One for outside temperature and one for inside temperature.
Mar 21, 2019 at 4:05 PM
AJFOSTER
MEMBER
I replaced the outside sensor and connector.
Mar 22, 2019 at 10:47 AM
CERTIFIED EXPERT
You need the inside sensor. That is the one reading wrong.
Mar 22, 2019 at 11:24 AM
AJFOSTER
MEMBER
So the inside sensor controls the display for the outside temperature? What is the part called specifically? There are three inside climate control parts listed on rock auto.
