Any Toyota 2006 and up models, if we disconnect battery for any reason and reconnected again most of times (not all times) it will run with misfiring (engine will not run normal) and the rpm's will go down. some times (specially with automatic transmission) engine will shut off when you put it in D or R.
to resolve this problem we should disconnect battery or ECU and reconnect it again for several times ( some times two to three times and some times up to seven or eight times! it is by luck ) then engine will comeback to normal firing .
I do not know why this problem with Toyota only and why some times only ?
even Toyota dealer informed me : it is normal and do not disconnect battery during maintenance.
Any advice ?
Thanks
Any advice ?
Thanks
Sep 18, 2017 at 4:38 AM
