Alternator not charging?
2000 FORD RANGER
25,000 MILES • 3.0L • V6 • 2WD • MANUAL
ROBIN RENFRO
I've already replaced it with a new one twice. I checked the big fuse up under the hood by where the relays and fuses are cleaned it all up. I have continuity between it have continuity between the black and yellow wire to the battery positive, but I've got no voltage to the yellow and white wire on the alternator. I think I'm supposed to have voltage there is anybody know.
Sep 11, 2022 at 11:38 AM
The yellow and white wire should have power. It is powered by a fuse in the under-hood fuse box.
I attached a wiring schematic below of the circuit, so you have a reference.
Recheck the alternator system fuse in the under-hood fuse box. In addition, it is important to confirm there is power to and from the fuse.
See pics below. Note: Pic 2 shows the fuse location that I referred to above.
Sep 11, 2022 at 6:21 PM
