Alternator positive wire red hot
2001 CHRYSLER TOWN AND COUNTRY
170,000 MILES • 3.3L • 6 CYL
JENNIFER CARPENTER
Large wire from positive bolt is red hot. It starts and runs. Should I replace alternator?Is it the grounding? I am a girl and need help. Everything seemed fine. I just got this car.
Jul 15, 2019 at 5:57 PM
CARADIODOC
  • 34,306 POSTS
Something else has to be going on that we aren't aware of. Alternators are physically incapable of developing more output current than they are designed for, so the only way for that output wire to get hot is if someone replaced the original alternator with some other unit that is capable of a lot more current, or it has at least two shorted diodes of the six, and that is creating a direct short to ground. That type of short would kill the battery in less than a minute, and it should blow the large bolted-in fuse in the under-hood fuse box.
Even when you have an alternator that is capable of developing a lot of current, it still is only going to produce exactly what is called for to meet the needs of the electrical system and charge the battery.
A better suspect is the original output wire became corroded or damaged and someone replaced it with a wire that is too small in diameter.
Before you start throwing random parts at the problem, have a mechanic perform a full-load output current test. That is one quick part of a normal professional charging system test. All of those tests take a total of about a minute. I'd also like to know the charging voltage, and "ripple" voltage. Ripple voltage is shown as a voltage on some testers that can make printouts, but most just show it on a relative bar chart as "low" or "high". We hope to see it's "low".
Post the values for those tests, then we'll figure out where to go next.
Jul 15, 2019 at 6:11 PM
JENNIFER CARPENTER
How would I do that if van is not safe to drive ? I am totally open to testing.
Jul 15, 2019 at 6:52 PM
CARADIODOC
  • 34,306 POSTS
You can start the testing yourself with an inexpensive digital voltmeter. Here's a guide on how to use one if you need it:
This article shows an auto-ranging meter that is more expensive. You have to select the range manually on the less-expensive meters like those you'll find at Harbor Freight Tools and hardware stores. Switch it to the 20-volt DC range. On that range, it will measure any voltage from minus 19.99 volts up to +19.99 volts. You won't hurt it if you connect it backward. It will just show a minus sign. Ignore that for this test.
With the engine running, measure the battery voltage by placing one probe on each battery cable. You must find between 13.75 and 14.75 volts. If you find something considerably higher, as in 17 or more volts, it's best to not drive the van as that high voltage can damage expensive computers. We'll discuss what to do next if that is what you find.
If the voltage is 15 volts or less, I'd drive it to a repair shop. Proper charging voltage as measured at the battery only means it is okay to do the rest of the tests, and for that, you need the professional load tester. If the voltage is not excessive, the alternator's output current also should be okay. It's that current that causes wires to get hot. To reduce the alternator's output current while driving to the shop, turn off everything electrical possible. You don't need the radio, heater fan, and air conditioning, and if you drive near highway speeds, the radiator fan won't turn on either. All those things get their power from the alternator, so turning off as much as possible reduces how much current will be flowing through that wire that's getting hot.
Jul 16, 2019 at 8:20 PM
