Alternator not kicking out voltage to battery
1992 CHEVROLET CAPRICE
100,000 MILES • 2WD • AUTOMATIC
QUANTAE
I have a new battery, and new alternator, but the battery keeps draining. I was told that the alternator is not kicking out any voltage to the battery. also, windows do not roll up or down. i am thinking I have some electrical problems some where but do not know were to start.
Dec 31, 2017 at 6:20 AM
Good morning.
Can you check the voltage at the battery with the engine running?
Dec 31, 2017 at 6:35 AM
QUANTAE
Yes I can, but when I am getting it checked they say the battery not charging. battery will drain after two or three days.
Dec 31, 2017 at 8:34 AM
Okay, can you tell me the voltage reading at the battery engine running after you charge it? Look for 14 to 14.5 volts. If you do not, check the heavy wire at the back of the alternator for battery voltage.
Dec 31, 2017 at 8:37 AM
QUANTAE
When I check the voltage at the battery it has no voltage, but when I check it at the alternator it does have voltage.
Dec 31, 2017 at 8:42 AM
what voltage? can you give me the readings?
Dec 31, 2017 at 8:47 AM
