I am helping my friend with above vehicle which he recently purchased. It is kind of a "beater" but meets his needs. When first purchased, the alternator was not charging. Thinking it was a bad alternator, he purchased a new one. The new one did not charge either. He had the new one bench tested and it performed just as it should. That leaves us with a wiring issue.
Looking in the engine compartment around the alternator, one can see several wiring changes. I think the previous owner "botched up" the wiring to alternator and that is reason it is not charging (probably also the reason he sold the vehicle).
Could you provide me a wiring diagram for the entire charging system on this vehicle? With the diagram we should be able to find and correct the problem.
Thank you in advance for your response
Apr 2, 2023 at 9:06 PM
