So, the engine is cranking over but not starting?
Generally speaking, an engine will need spark, fuel and compression to start.
So, if it is cranking over, it tells you that the starter is good.
Now you will have to check and see if you have spark to the plugs.
Also, can you hear the fuel pump come on, when the key is turned to the on position?
Take a look at this guide, it covers the typical issues when the engine cranks but does not start:
https://www.2carpros.com/articles/car-not-running-advanced
Feb 2, 2022 at 7:02 AM
