Alternator issue, gauge moving down after vehicle is running for fifty or more miles
2009 GMC ENVOY
158,930 MILES • 5.1L • V8 • 4WD • AUTOMATIC
CARNEYLAKE
I have the vehicle listed above Envoy/Denali . I am on the third alternator,
two rebuilt and a brand new one since February of this year, plus a brand
new battery. Here is what is going on: I thought the two rebuilt alternators
were defective, so, they were replaced. When the second one allegedly
failed, I told AutoZone I wanted a brand new one. I had it installed last
week and, it was fine for a few days and now, after I drove about 60 miles
straight, the needle dropped from just above the halfway mark, to between
zero and half way, yet, the battery is brand new. The connections are fine.
Does anyone know what could be causing this to happen? On the second
rebuilt alternator, the five months old battery was damaged, so, I had to
replace that, too, last weekend. The GMC dealer says I need to buy only
a GMC alternator, which is garbage, because they want to charge me over
$500.00 just to have one installed. Something is causing the alternator to
charge erratically, causing the needle to vary, and I don't want to be
stranded.
Jun 18, 2019 at 7:18 PM
Good morning,
Did anyone check the belt tensioner to be sure the tension is correct for the alternator to work?
https://www.2carpros.com/articles/how-a-serpentine-belt-tensioner-works
What is the voltage at the battery with the engine running?
Jun 19, 2019 at 3:16 AM
CARNEYLAKE
When the new alternator was installed last week, I had it done by a reputable local mechanic at a long time business in the city where I live. I have to assume he tightened the belt to specifications, but, regardless, I made an appointment at another auto repair shop to attempt to troubleshoot. I did do a finger test and the belt was firm and tight. plus, it, too, is a brand new belt. I will have the repair shop on Monday, test the battery with the engine running for about an hour.. that should be enough time for the alternator to run to see if the gauge starts dropping, as the repair shop they won't drive the vehicle 50 miles.
Jun 19, 2019 at 6:00 PM
Okay. Keep us updated.
Jun 19, 2019 at 9:26 PM
