Alternator belt diagram needed
1997 HONDA CRV
248,000 MILES • 4 CYL • 4WD • AUTOMATIC
KALESH12345
It appears my belt is gone from the alternator so I have nothing to take note of as I plan to put on a new one. It looks fairly simple. What other belts will I need to remove? Should I replace those as well? I cannot seem to find a clear diagram.
Jan 7, 2017 at 2:18 PM
MHPAUTOS
  • 31,937 POSTS
Here is the link for all the info you need to do the belt replacement.
https://www.2carpros.com/diagrams/honda/cr-v/1997
Jan 7, 2017 at 3:25 PM
MHPAUTOS
  • 31,937 POSTS
If belts are suspect it is better to replace all at the same time, just to be safe.
Jan 7, 2017 at 3:26 PM
KALESH12345
AC and power steering belt have to be removed to install new alternator belt? Can this be done without removing engine mounts and hoses?
Jan 7, 2017 at 3:38 PM
MHPAUTOS
  • 31,937 POSTS
yes, the belts can be replaced with out stripping this out, it may be a tight squeeze but you should be able to get it done
Jan 7, 2017 at 9:28 PM
