Is my alternator considered to be a two wire or three wire alternator?
1992 NISSAN HARDBODY
999,999 MILES • 2.4L • 4 CYL • 2WD • MANUAL
CADE BROWN
MEMBER
FOLLOW
Which wire is the exciter wire, and which is the voltage sensing?
Aug 2, 2023 at 9:35 PM
CERTIFIED EXPERT
The yel/blk wire is the sensing wire here is the alternator wiring diagrams so you can see how the system works. Yours is a three wire sensor. Check out the images (below). Please let us know what happens.
Image (Click to enlarge)
Aug 3, 2023 at 12:16 PM
CADE BROWN
MEMBER
This isn't how my alternator is set up, mine has the wire that goes to the battery and a plug with two wires ran out of it. I need to know what each wire that comes from the plug are one is the sensing and the other is the exciter on the diagram shown the exciter is the ground wire.
Aug 3, 2023 at 12:24 PM
CERTIFIED EXPERT
I found this wiring diagrams it might be better. there is the sensing wire is the charge indicator wire.
