Alternator
2000 MERCEDES BENZ 230TE
250,000 MILES • 4 CYL • 2WD • AUTOMATIC
JUDYSISTI
I just had the alternator replaced and my car starts, but it will not pick up speed. Is it possible they put the wrong alternator in? I have a 230C Kompressor. Would the alternator be the same for a 230C and a 230C Compressor? Thank you. I need help, cannot drive my car.
Feb 11, 2018 at 8:02 PM
No, it sounds more like they forgot to connect something in the intake portion of the car. I would lift the hood and look at all intake and inner cooler tubing. Also, lets run the codes to see what comes up.
Feb 13, 2018 at 11:06 AM
JUDYSISTI
They told me the reason the car was not picking up speed is because it is not shifting properly, and if I shift it myself it will run okay. I am still afraid to drive it. Does this all make sense to you?
Feb 13, 2018 at 1:00 PM
We need to see what codes or in the car to point us in the right direction. Can you scan for codes or know someone that can? You can get a codes reader from Amazon for $25.00
Feb 14, 2018 at 10:10 AM
