internal voltage regulator what does the " I " and " A " pins connect to?
2005 FORD EXPEDITION
200,000 MILES • 3.8L • V8 • 4WD • AUTOMATIC
CUSTOMER
internal voltage regulator.
Sep 15, 2021 at 1:32 PM
SQM
  • 6,383 POSTS
The 'I' pin is the alternator sense circuit, voltage supply at all times, and the 'A' pin is alternator monitor.
Couple of helpful articles on wiring:
I have attached the wiring schematics of the charting system as well as the alternator replacement procedure your reference.
Thank you.
Sep 15, 2021 at 10:34 PM
CUSTOMER
Sir/ Madam,
Based on your response , The "I" pin connects to positive power on the battery and the "A" pin would connect to Negative ground through a gage or light or a diode .
Is that correct????
Sep 16, 2021 at 6:28 AM
CUSTOMER
I only have 2 wire "A " and " I " (marking on connector).
Sep 16, 2021 at 12:03 PM (Merged)
Good evening,
I attached the wiring diagram of the charging system for you as well as the connector diagram with the location of the wires for you.
Let me know if you have any other questions.
SQM
  • 6,383 POSTS
Yes, that is correct.
Sep 18, 2021 at 9:33 PM
