check engine flashing P0748 code?
2002 SUBARU OUTBACK
180,000 MILES • 4 CYL • 4WD • AUTOMATIC
TLC4HIM2
Hit a rock and the dash light came on, alternator, oil along with check engine.
Transmission oil level good, no leaks. I went to AutoZone and P0748. came up. AT Pressure Sol failure. Pressure control solenoid "A" electrical. Do I just need a sensor?
Feb 28, 2023 at 12:31 PM
When you hit the rock did it dent the transmission pan? If so, this can restrict the flow of transmission fluid to the filter or pick up tube which will cause the code P0748 Pressure Control Solenoid A. I would raise the car up and inspect the transmission pan.
Here is a guide to help:
Please go over this guide and report back.
Mar 1, 2023 at 11:40 AM
