All problem lights go on abs, trac, brake, pcs
2002 OLDSMOBILE INTRIGUE
95,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
LENCARS
When first started no warning lights are on but after the second start all five warning lights are on and the power steering feels a litter harder to use. I have checked brake sensors wires and they seem ok. A mechanic says I need some very expensive parts to fix the problem, I checked with a dealer and the price, would you believe 3,000.00. The car isn't worth that much. If you have an answer I would loe to know it. Thank you.
The car looks like new!
Jul 3, 2014 at 5:07 PM
HMAC300
  • 48,601 POSTS
have batter checked for condition including load test autoparts do it for free. check belt and tensioner recommended replacement is 60k the battery may be your problem.
Jul 3, 2014 at 5:12 PM
LENCARS
Had belt changed about 5k ago. The bat maybe the problem will check. ty
Jul 3, 2014 at 5:27 PM
