Hello DURANGODODGE,
My information is telling me there is a circuit breaker behind the left kick panel that powers the windows. However, it looks like it also runs power to the sunroof motor (if you have it), as well as the power locks and door modules.
But locks work fine, it's only the windows that aren't working. I think testing the circuit breaker is a good first step so we can make sure there isn't an issue with it so we can rule it out.
To do this you will need a multimeter.
Here is an inexpensive one I found if you don't have one:
https://amzn.to/3NUrAOd
Here are some instructions to use one if you haven't before:
What you need to do is pull it out slightly so that it is still connected but you are able to put the test lead on it.
Touch the black lead to a known good ground on the body.
Then take the red lead and touch one terminal then the other on the circuit breaker.
You should have 12 volts with the key on engine off on both terminals.
If only one terminal has 12 volts, the breaker is bad and needs to be replaced.
If you don't have power on either terminal could be power supply issue or ground.
I am adding a wire diagram for you, as well as an image of the location based on my information.
I am also adding a picture of the part.
If you need it, I found one on RockAuto for you here:
https://www.rockauto.com/en/catalog/dodge,2009,durango,4.7l+v8,1442700,electrical,circuit+breaker,2504
Part number is CB191125 from BUSSMAN. Your local auto parts store should have it as well.
Let me know if you need any help when you go to test and based on what we find we can go from there.
Thank you,
Brendon
Jun 30, 2023 at 3:30 PM
