We have been asked to provide some information on winterization stuff for your car. Any help is appreciated. Thank you.
Mike
What are some common winter car problems that drivers should watch out for?
How often should you clean off your car headlights to prevent winter grime build up? What are some dangers of this build up? Would coating the lights with WD-40 or car wax help repel such build up?
What makes car doors get frozen shut in the winter? Is there any way to prevent this from happening—for example, rubbing cooking oil into the rubber seal to repel moisture?
If your car is in storage for the winter, how can you keep pests/rodents from making nests inside the engine? Are there any alternatives to mothballs?
Why do car batteries tend to fail in the winter? Is there anything you can do (preferable a DIY solution) to safeguard them from corrosion/rust?
What are some dangers associated with car tires in the winter? Should you clean your tires early in the season to prevent slush buildup?
Is there anything you can do to prevent ice/frost build up on your windows (preferably a home remedy like white vinegar or shaving cream)?
Mike
Aug 26, 2010 at 10:07 PM
